apuszczalowski
- January 17, 2011
- Welland, Ontario
- 1999 Explorer Sport
So I was driving to my hockey game tonight and ran into a huge problem with my truck.
The truck is a 1999 4.0 SOHC Explorer sport, it drove fine all day, gas was low so I filled up on my way home from work, no signs of any problems. I go to leave to go to play hockey and about 5 minutes (driving) from my house, the trucks motor got a little bit louder then usual (not really that noticble but just a bit louder). I kept going thinking it was just the muffler maybe starting to go and all of the sudden I started to feel like the truck was getting a little sluggish. I look down and was still cruising at about 2,000-2,500 RPM so I let off the gas and then back on it and the engine just lost most of its power, then the tach went dead and the motor stopped leaving me enough to coast tot he side of the road and into a parking lot.
I put her in park (engine won't crank in neutral) and the motor just cranks (and there seems to be a "slapping" noise) and won't fire. I tried a bunch of times and it won't fire. I looked around under the hood and can't see any visual signs of a problem, try again and the same thing. Walk over an hour back home in very cold and windy temperatures, take my girlfriends car back to get our hockey gear and try it again and still nothing. Go back home and called a tow truck and off it went to the mechanic.
Does anyone have an idea what may be wrong? according to the haynes manual I have it could be anything from a dirty or clogged fuel filter to a dead fuel pump all the way to the timing being off a little. Has someone had this happen before? I was not getting a check engine warning (can't tell if I have one now, if I leave the ignition in the on position, eventually all the lights ont he dash go off except the check engine and the check guages).
I am really hoping for the clogged fuel filter or dirty injectors, or bad spark plugs, (doubt the injectors, I use injector cleaner every couple of fill ups) or even a dead pump, but knowing my luck its going to be a rear timing chain or one of the cylinders lost compression. I'm leaning towards a fuel problem only because after all the cranking, I'm not smelling any gas like I do on my old Dakota pickup that also wont start and only cranks (I think that one has an ignition/spark problem cause it cranks but I hear the fuel pump when i turn the key and smell gas after cranking for a bit)
When bought the truck the dealer told me that he went to a Ford Dealership to get the rattle looked at and they said it was a sticky valve or lifter, but I'm starting to think they screwed up or he screwed me and its a timing chain issue thats going to cost a fortune to have fixed, I'm already down $50 for the tow. This was supposed to be a winter beater to get me through the winter cause I didn't think my Dakota would after it was leaking coolant for atleast 6-8 months and I lost heat, plus noticed an oil leak. I still ran just fine until I let it sit for about 2 weeks without starting it.
I'm dreading the call from the mechanic tomorrow (would do it myself if I had a warm garage of my own, or lived somewhere where there isn't 2 feet of snow on the ground in my driveway
