MiWiAu
- August 23, 2016
- Milwaukee
- 2013 Explorer Sport
Hey all!
New member and recent owner of a 2013 Explorer Sport. I was experiencing vibration (and oscillations in the steering wheel) at speeds 55+ MPH. I took my truck to a tire store, and they were able to diagnose it as a bad LF tire. The vehicle has cheap Chinese Nankang SP-5 tires ($125/ea on Amazon). They were able to get it to balance with an excessive amount of weight (6 oz !!), and moving it to the rear axle eliminated nearly all the vibration. I don't want to drive it like this for long, and I am trying to work through the dealer from which I purchased the vehicle, but I anticipate I will be fixing this on my own.
I've searched many threads, and I've seen many answers on whether I can replace one tire or if they all need to be replaced. My hope was to install one of the cheap tires until they are all due to be replaced. I really don't want to pay another $1000 for tires after shelling out $31k for the vehicle on Saturday.
I found this statement on p.114 of the 2016 Police Interceptor Utility manual, and I was wondering if there is anything unique or different about the 2013 4WD system that would preclude me from installing only one new tire (I did not see the same statement in the standard 2016 Explorer manual or my 2013 manual):
Based on tire size, the 28.6" diameter of the 245/55R18 Interceptor tire is smaller than the 30.0" diameter of my 255/50R20 tires, so perhaps the larger rolling radius of my 20" tires would put them out of spec with mixed tread. The example above, though, seems pretty extreme - mixing 17" low tires with 22" high tires. I need to double check the depth of my current tires to see how worn they actually are, but I figured I'd throw this out in there in the meantime. It seems as though I'd be okay replacing one for now, but I wanted to check with the experts
Thanks!
Major dissimilar tire sizes between the front and rear axles (for example, 17 inch low profile tires on the front axle and 22 inch high profile tires on the rear axle) could cause the AWD system to stop functioning and default to front-wheel drive or damage the AWD system. However, the AWD system is capable of tolerating any combination of new and worn tires of the same original tire size. For example, using 3 worn tread tires and 1 new tread tire all of the same original tire size, can be tolerated by the AWD system.
Thanks!
