lizard00
- April 19, 2020
- indiana
- 2002 Ford Explorer XLT V8
Okay so I have been trying to diagnose exactly what's causing this noise for a while now and i'm leaning towards a wheel bearing/maybe brakes? but not sure enough to replace anything quite yet. Out of seemingly nowhere one morning, when I tried to backup and leave my driveway the passenger rear wheel was binding and making an extremely loud grinding and sort of popping. I had someone else drive it while I listened and the sound is 100% coming from the wheel area, not the differential. Before this started the abs light would come on after driving a few feet, well after this started when that abs light comes on the noises and binding stops. It won't do it again until the key is turned off and on and it will start over again. I scanned the abs code and replaced the rear abs wheel speed sensor on top of the diff. Now, instead of the noise going away when the abs light pops on its continuous. Looking at that wheel, it is not aligned correctly at all, as well as the tread being worn unevenly. The rear toe link looked way off compared to the other side, and the sway bar link was literally moving up and down about a full inch. Im guessing it had been driven like this for at least 2-3000 miles as thats how long ago my brother had that toe link and sway bar end link, along with the rear struts and springs replaced. Apparently the mechanic didn't bother even trying to get the alignment close or tell him it needed to be aligned. The brake caliper seemed to be really loose as well, and the pads were bare on one end and had all the braking material on the other. The rotor doesn't look too great either. Even with the caliper, pads, and rotor off and turning the wheel hub its still binding. So obviously im going to have to replace all the bad brake parts and rotors n pads on the other side as well, but I don't want to waste money on a wheel bearing is thats not what the grinding is. If that was the problem, why would the abs light coming on make it stop? Any insight would be appreciated, thank you
