John G
- October 28, 2002
- Milford, CT
- 93 Eddie Bauer
Ok, I tried everything mentioned. My 93 EB has flickering lights and a jumpy volt meter. It comes down after around 20 minutes but all the lights still flicker at idle. Here is what I did so far:
1. cleaned battery terminals and all connections on alternator.
2. added a ground wire from - side of battery to frame ground.
3. brought the truck to Autozone and they hooked it up to this fancy computer and both the alternator and regulator check out fine.
4. Any suggestions?? Please help. I can't imagine that all this flickering is not hurting something in the long term. Could it still be the alternator even though it checks out fine. I disconnected the multipin plug to the alternator while it was running and the flickering stopped although the voltmeter showed that the battery was discharging at the time.
