MarkNM
- September 10, 2012
- Santa Fe, NM
- '93 & '02 XLT
I have been looking on this forum for a solution to my problem but haven't found one and am hoping someone on this forum might have some advice.
I've been repairing the brakes on a '93 XLT 2wd. Replaced drums, rotors, pads front and rear, and all the springs and small parts of the rear. The flexible brake hoses that run from the top of the wheel well to the front calipers need to be replaced as they are cracking. I understand the steps involved :
1 Unscrew hardline male fitting from the female socket at the top of brake hose.
2 Remove bolt that connects hose to caliper
3 Remove retaining clip that holds hose to top of spring bracket
4 replace with new hose
Well step 3 there is turning out to be a real PIMA I've searched this forum high and low and although several people have asked how to remove this clip nobody has given an answer, at least not that I have been able to find.
I've tried pulling it off with pliers, hooking a screwdriver under it and prying, and tried to use a drift punch. Made the thing spin a couple dozen times and scrapped up my knuckles, but the clip is still there.
Any advice is appreciated.
