KBoomBoxx
- November 16, 2005
- Stanardsville, VA
- 1994 Ford Explorer XLT
Read through dozens of threads on problems/noises coming from the front brakes and still can't determine what mine is... so far I replaced all front bearings, and brake pads... had rotors turned... and one caliper needed replacing... I think that the other one might now need to be replaced... also replaced the caliper guide pins... bottom line is that the drivers side ocassionally clips and pulls for a brief moment... at first thought it was the bearings, then the rotors, then the pads... had several problems with the same side... backside pad fell forward? then the guide pins started pulling out? replaced em... problem still exists? its not all the time... its only on occassion... I can't figure out why or when.... any suggestions?
