SupaSwope
- August 5, 2016
- Florida
- 99 Mountaineer 5.0 RWD
So I installed a new front suspension over the weekend and had it aligned on Monday. So now uppers, lowers and tie rod ends have grease fittings but when I hook up my "new" (was in box when I took it out to use it) grease gun it pumps grease out but the connector on the gun seems to be broken.. So I think?
I can easily slide the fitting on the grease gun on and off without having to tighten the fitting down on the gun itself. I take it as a sign of a bad gun connector right? Because also when I pump the gun the grease comes out but doesn't go threw the fitting but out the side and just goes on top of the joint of whatever I am trying to grease. These are new parts and fittings so nothing is clogged or old.
Should I go buy anther gun? I think I sall they sell the hoses at the auto parts store.. Should I buy one of those? I don't know if I should buy a new one or what..
