sqhurt
- December 10, 2007
- ohio
- 93 sport & 4 door
Have 93 xlt 4x4. Has 4 wheel Abs with drums in rear. Last week I put on new shocks,drums,shoes,hardware,rotors,bearings.
Problem I'm having with grinding is from about 5 mph to 15 you can hear like a grinding noise. Not so much metal to metal but like pads on rotors. But as soon as you touch the brakes the noise stops. Oh and there is a new caliper on the driver side and new brake hose on the passanger side.
I jacked car up in front and turned wheels. You can hear the noise as pads are touching the rotors. Also shacking tire up and down and side to side has no extra movement.
As far as the brake pedal itself. I bleed the brakes 3x twice with truck off and someone pumping, and once with truck running and someone pumping. I noticed with truck off you can push the pedal about 3 times and hear like air escaping while pressed but after 3rd time you have a great pedal. Now on the other hand while the truck is running you can pump them and still seem to hear like whush sound from the driver seat. And as well under the hood while pedal is pressed in. On side not the float inside the master cylinder wouldn't come up by itself, so had to use a pick to bring it up.
While doing the whole brake job the master cylinder to go empty. I've tried searching on how to bleed abs system or the hcu and reading all kinds of stuff and seems to be different. Any and all help is greatly appreciated Thanks
