Icuff4cash
- February 22, 2016
- Las vegas
- 1994 aerostar awd
Well after running my new scan tool I received all clear message but still get 8-10 mpg in the city. I fail to find out why
2. I bought a head light repair kit, sanded buffed polished and coated 100% worked. After spending $50.00 I can say it works great but if you have a few tools you can cut it down to about $15.00 I bought the Mcquires Kit it said it came with a uv sealer false claim. It came with a uv polish. What you need to clear headlights my lights were a milky white you could not even see threw them and clear lens an eBay were $67.00 each the kit comes with enuff to do 2 cars but if you make up your own kit for the money you have a nice side bussness and you can make between $50-100 per car. My lens came out 80% clear were you can see reflexion in the back reflector. The real secret is you need a can of clear with uv protection with out it your lights will refog from the uv rays. Here's what you need.
1 cordless drill
2 800 grit wet dry
3 1500 wet dry
4 2000 wet dry
5 sanding disc pad
6 buffing pad
7 rubbing compound for plastic /motorcycle windshield compound ect...
8 clear uv coating
9 painters tape and new papers to protect paint
Sand all lenses from 800 to 2000 until smooth you lights will be hazy looking.
Now use buffing pad and compound buff until clear this is the magic . Once you get it clear wipe off all residue and prepair to clear coat. This is going to be the clearest your lens will be the clear coat spray lens light coating. 3 coats will do it. The wife's boss has a Benz and saw my work offered me $100. To do his Benz . Mother Germany wanted $500 to do what I did in under an hour. To dry clear coat faster once painted turn on lights to warm lens. If your good and have the time this is a nice income. A dealer can get at lease $300.00 more for a car with good lens they don't have the man power to do there cars. If you have a lot close to you offer to do the cars for $75.00 it will cost you $5.00 per car in supplies and less than a hour. Easy money
My next job today I removed my grill and painted it gloss black looks better than puke gray. So today 2 out of 3 a'nt bad
1 cordless drill
2 800 grit wet dry
3 1500 wet dry
4 2000 wet dry
5 sanding disc pad
6 buffing pad
8 clear uv coating
