jimbo231
- March 5, 2009
- 2001 Ford Explorer Sport
I had the heater control valve replaced last year on my 1998 explorer. Ever since I have had no heat. The heater hoses are both the same temp so I don't think the heater core is plugged. When I turn on the heat there is no vacuum an the plunger stays out on the valve. When I turn on the air conditioning , vacuum is applied to the valve sucking the plunger in. I was just wondering if that is normal or backwards? Also does it matter how the two hoses going in and out are connected or can the be connected wrong?
