Installing the amp and keeping with all of your stock equipment may not be as easy as it sounds. I guess first and fore most you need to determine whether or not the amp will be compatible with your stock speakers. Stock speakers usualy do not have the power handling as after market speakers. Secondly the head unit that is currently in your vehicle may or may not have RCA outputs. These outputs would be the prefered method of sending the input signal to your amp. Due to the ease of installation, and the amount of wire that has to be run to the amplifier. If you don't have RCA out's on the back of the head unit you will have to run individual channel signals to the amp inputs. Next you need to decide how you want your system setup (which speakers to amplify), 4 channel (LF,RF,LR,RR), 3 channel (LF,RF, sub bridged, rear channels on factory head unit.), two channel (LF,RF bridged). As you can see there are many options for amp hook up. Mounting your amp has probably has many options if not more. This is more of a personal preference. Do you want it where people can see it? Do you want it hidden? What ever you do give it some air for cooling they get really hot and will go into thermal protection. It shouldn't be nessasary to run 12 gauge wire. You can do just fine with 16 gauge and up. This again will depend upon how many watts you want to send to the speakers.
If I may suggest. Get everything that you need to make your system complete, and do it one shot. You really don't want to be pulling stuff apart over and over again. If you don't feel comfortable with what you are doing, please please have it done professionally. They will warranty the work that they do, and you won't have to worry about cooking your dash or anything else(speaking from experience).
With allot time I could walk you through it. Try going to this site and see what kind of info you can dig up.
Home | Rockford Fosgate ®.
They have some pretty good explainations there. It should give you a good Idea of what you are dealing with and either inspire you to go to work or go to the install shop.
Hope this helps
Jeff
