Howdy from Oklahoma!
I'm new to this board and have spent the last hour searching for tips on troubleshooting the high mount third brake light for a 97 Explorer. I picked up a ballast and light from my local JY and thought I could do a quick swap starting with the ballast first.
Well - no luck the JY ballast and light. They don't work either. I benched tested both the JY and the Explorer's ballast and the output seems to be around 100 millivolts which doesn't make sense. Thought it should be at least 80v to power the neon strip light...so that may be my problem.
I also tested both the JY and the Explorer's neon light strip with a meter to see if there was continuity - and there wasn't for either light. Normally that would mean there is a break in the light circuit. Would that logic also apply to this neon setup.
Thanks--Marc
PS - Great site - I could spend days here.
Thanks--Marc
