RobertFord
- November 14, 2011
- Amsterdam, Netherlands
- 1991 Ford Explorer XLT
Hi All,
I recently noticed my front hubs (both left and right) being hot after a drive. I checked the bearings, which seemed fine, but were nearly dry! So i re-greased them and tightened them properly, but the heat is still there.
It's hot to the point where you're not sure if you can still hold it, but you still can (just).
I'm figuring I might have a dragging brake problem, but I'm not too sure as it concerns both wheels equally, they are also equally hard to turn. Could just having a brake fluid change fix the problem? I think the problem must be further up the chain than the individual caliper because it affects both wheels equally.
Looking forward to your help!
