How many quarts? | Ford Explorer Forums - Serious Explorations
How many quarts?
Fordman999
2003 Ford Explorer XLT
Just wondering how many quarts of power steering fluid my car actually holds in total. I am changing my power steering pump this week? Also how many quarts of coolant total? 2003 ford explorer 4.0 sohc
No capacity spec given for the power steering system. One quart is "usually" more than enough to flush until Mercon
V ATF runs clear. Two coolant capacities given for the 4.0 SOHC cooling system. Use Ford approved Zerex G-05 if Motorcraft Gold is too expensive from the dealer. G-05 is around $15 per unmixed gallon available at most NAPA and O'Reilly stores.
(Pages 260-261)
http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/03expog5e.pdf
http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=136391
https://www.scribd.com/doc/312832108/power-steering-pump-8212-4-0l-sohc-removal-and-installation-pdf
https://www.scribd.com/doc/312832020/power-steering-system-flushing-general-procedures-pdf
When I did mine ('98 SOHC) I just drained it until it stopped dripping then measured it with a gradient container. Then just replace the same amount that came out. Then top it off as needed. You may not get >every< drop out of it, but enough so that the little that remains is insignificant. :salute:
Koda has the best method I've seen to get close to the optimal 50/50 ratio.
Never trusted the accuracy of cheap testers such as the Prestone AF-1420.
It's easily a gallon that remains. Really no way to get the water out of the block. I guess you could do a couple of flushes with distilled water before adding antifreeze, but I couldn't worry about it too much.
I use Prestone or Peak 100% antifreeze, whichever is on sale. Don't dilute the first gallon you put in and you'll be pretty close to a 50/50 mix. When done, run the engine with the radiator cap off or loose to help expel trapped air, which can be difficult to do on the SOHC engine. I install the antifreeze slowly via a small syphon hose. This also seems to help expel any trapped air.
https://www.explorerforum.com/forums/showpost.php?p=3455469&postcount=5
Since that omits A/C info...
Thanks TechGuru, always handy to have lists like this.
You da man tech guru I'm printing this out for reference
