rathrbcruisin
- September 17, 2015
- Michigan
- 1998 Explorer 5.0 AWD
I have a 21 gallon tank and i'm usually putting 16.5 gallons in at fill up. The computer says I have 3 gallons left, which i'm sure is probably not exactly 3 gallons but probably close. do you think there may be 5 gallons left in the tank when it says 3? I had an issue with P0455 which ended up being the vapor canister had a hole in it. I blew the line going to the tank for the vent while replacing the canister to make sure it was not plugged. Air went into the tank, and then fumes and air came back out so i think that is ok. I also replaced the purge valve and the vapor canister solenoid. the main thing that makes me wonder if it is filling all the way is many times it drops off of full after 40-50 miles, then by 60-70 miles its on 3/4 tank already. usually i'm at 150 miles by 1/2 tank and fill up around 250-270 miles.
how many gallons are you putting in at fill up?
