SouthernSAR
- December 21, 2011
- Naples, FL
- 2004 Explorer ST XLS
I'll start by saying that this is a really easy fix and can be done by almost anyone, even people who have never fixed anything on their vehicles by themselves. Now, on with the show!
Tools you'll need:
-T30 torx bit (and driver)
-Rag(s)
-Maybe pliers (I didn't need them)
Now, the P0193 code means that you have a bad Fuel Rail Pressure and Temperature Sensor. These can be obtained from numerous places including dealerships. I got mine from RockAuto.com for a small fee of $65.79. Part numbers for the ones Rock Auto sells are 5S7254 and FPS5. The parts look like this:
and can be found on the fuel rail here:
This is what it looks like in your vehicle:
You can start by either unplugging everything and then unscrewing the sensor or you can unscrew the sensor then unplug it. I found it easier to unscrew then unplug it. The electrical plug on the back has a little tab that you push down on the top and it pulls right off. The hose also pulls right off.
Now once you've got the little bugger unscrewed, it'll take a little force to get it out. I didn't clear the rail before I pulled it and as a result a little fuel spilled out into the engine compartment, nothing major though. That's what the rags are for.
Clean mounting point:
Next just take your new part, make sure it is clean (the fuel rail should also be clean) and plug it in and screw it down. Voila! Clean up, turn on the engine, check to make sure it runs and that the sensor isn't leaking fuel. Maybe even take your vehicle for a test drive. You'll still have to manually clear the code, or just live with the CEL until it turns itself off.
Old vs New:
If I missed anything let me know!
Tools you'll need:
-Rag(s)
Old vs New:
