ediller3
- September 4, 2007
- ohio
- 2002 explorer xlt 4x4
A/C doesn't blow cold at all. I bought the A/C manifold gages from Harbor Frieght and tested the system. The outside temperature was about 90 degrees. The low side gauge read 20 to 55 psi as the compressor cycled on and off. A complete compressor cycle was about 10 seconds. The high side pressure gage read 120 psi. The line on the low side of the system never got cold but the high side line did become hot. I believe this means I need refrigerant. Would I be correct?
Also does anyone have instructions on how to add refrigerant using the A/C manifold gage.
Thanks for your help
