flusterated
- August 31, 2011
- 2000 Ford Explorer
Hello all. I have a 2000 Explorer 4.0 V6 that has an intermittent condition. The code from Autozone is P0172. Usually when the engine is cold (but not always) the engine will run rough, especially when the RPM's are low and the car is cruising around 40-50 MPH. During acceleration and after the subsequent downshift, the "roughness" will subside. This also happens when accelerating from a stop. I have replaced the MAF, Coil Pack, and the O2 Sensor (behind the catalytic converter). The code says that a Bank 1 Rich condition exists and the culprits might be:
1-Misfire
2-Defective O2 Sensor
3-Fuel Injector problem.
My problem is that I only need the truck for about 1 more month and I have a few trips to make with the family. So i need the truck to be reliable but I cant afford new injectors.
My question is since it's not always happening what could be the culprit? I have on occasion driven 2-3 days without any issues. Other times it happens all day, but happens mostly during the first (cold) start of the day. If anyone has any helpful tips, i would greatly appreciate it. Thank you.
1-Misfire
