fast_dave
- June 6, 2005
- East Bay - Nor Cal / PRK
- '98 Spt 4.0 OHV 5 spd 4x4
Get a Motorcraft rear main seal.
I have used a couple different brands on my 4.0L, and done this job 3 times on it. All 3 have failed. I thought I must have been installing it wrong, BUT.. I used the seal tool each time. I searched this problem out here, and found that you really should only replace with a Motorcraft seal. The seal lip is special, and differs then aftermarket brands. Lesson learned, and when I do this for the 4th time, I will use the Ford seal, and the seal tool.
@gmanpaint
Your post intrigued me enough to go back in my Ex's service records.
OK - to start, the FORD OHV Engine has a reputation for rear main seal leaks.
It may be an internet myth repeated over and over, but many say the reason is that crank snout was polished TOO fine, allowing oil to slip past.
Apparently, the sleeve isn't polished as fine as the crank snout - hence the reason for the sleeve.
I don't recall any posts saying the sleeve was included because of a circular ring being ground into the crank snout.
OK - back to my OHV Ex. In December 2007 @ 90,579 Miles I had a local mechanic replace the rear main seal in my OHV.
I don't have any note as to the brand of rear main seal he used, BUT I do know it was aftermarket due to both memory AND my next service entry.
Next service entry - March 2008 @ 93,958 Miles and I have a note that the rear main seal was leaking, and my mechanic replaced it again, this time with FORD Part Number F5TZ6701A. Even back then I remember him complaining that it was around $40.
It was a LONG time ago, BUT now that my brain juices are flowing I remember him saying that when he picked it up, the FORD parts guy said it had to be installed with a special tool to assure it being leak free. I imagine this is the same tool that is mentioned earlier in this thread. I remember this because my mechanic had to wait until the weekend to borrow it from a service guy buddy that worked at the local FORD dealership he bought the seal from. The guy that worked at FORD didn't want to give it up until he had the weekend off. This caused me to be without my Ex for a few days more than originally expected.
I ran a GOOGLE search with the parts number, and found a guy on EBAY that offers a 100% FORD 4.0 SOHC Timing Chain Kit, and he includes the same Rear Main Seal - FTZ6701A - this is a long way to say it'll fit an SOHC.
OK - hope this helps @koda2000 and good luck with your rebuild!
