Jumps out of 5th gear | Ford Explorer Forums - Serious Explorations
Kelrich
Baker City, OR
1990 Ranger 4x4 4.0 M5OD
Same problem as expressed in Medic-Holt`s post in 2010. After rebuild the trans pops out of 5th gear. It seems to go in 5th, but when you let out the clutch it pops out. Any thoughts ????
Thanks in advance for any hidden M5OD guru`s.
I can't say about a M5OD but when a standard trans wont stay in gear, it could be a bent fork, bad synchronizer or one that isn't assembled properly, or the teeth are badly worn.
M5od
Thanks for the reply. I found I had not put the 5th/reverse slider with the dot, facing the output shaft or rear of the trans, and with this reversed it will not allow 5th gear to stay in.
