nasty_north
- November 14, 2010
- canada
- 03 Eddie Bauer v6
Hi, i just bought an 03 explorer 4.0 with 224 km to drive this winter in Toronto Canada. It currently has a low oil light and service engine soon light on. I pick up the car tomorrow.
What type of service or matinence should i do to help make sure it lasts through the tough winters i have planned for it? i have read and searched and this is what i found so far:
1) oil change & filter
2) fuel filter
3)flush coolant / thermostat
4) differential and transfer case oil changes
5) lube rear drive shaft spline
did i miss anything? can you reccomend type of fluids? threads? i heard that 0w30 is a good engine fluid to run to keep pressure up. or should i stick to 5w30.
on a side note i need to repair a passenger side tweeter and it looks like the rubber insert below the stereo is cut. it is half the size it should be, and there is a 1" diametere hole in the center console. is that hole normal? is the rubber inserts a one shoe fits all for the 03's . i dont want to buy the wrong inserts.
reference pic:
any help for a complete newb to explorers would be greatly appreciated. cant wait to pick it up tomorrow and get started!
2) fuel filter
reference pic:
