roccov12345
- January 21, 2005
- Hopewell Junction, NY
- 98 Mountaineer
ok all, here I go again....
1998 Mountaineer, since I bought the car the rear diff has been leaking so I decided to tackel the job over the weekend. Inspected the leaking to be coming from the pinion seal. Disconnected the driveshaft, took off the pinion nut (PITA!). Pulled off the disc that the driveshaft connects to (needed a gear puller) then pulled out the old pinion seal. Put in the new seal, put together as a took it apart and it's still leaking.
I noticed the reason it was leaking in the first place is because the plastic sleeve on that disc thats in there was catching on the pinion seal causing it to spin the seal with the driveshaft as it turns. This is whats happening now. I didn't tap the seal in because it didn't look like I could. It sit in there the same way that my 95 explorer sits with a little lip hanging out. Any ideas? Should I tear it back down and tap the seal into place? When I put it in it just kinda moved around in there. HELP! :fire:
