Digitalgp
- February 13, 2018
- Hudson valley
- ‘15 XLT
Wanted to share here. Did my first mod on the ‘15 xlt. Being compared to the factory lights on my old ‘07 Limited & the halogen projectors on my ‘12 fusion the lighting output was weak and I needed to upgrade. I have done a number of hid swaps, however the first one I did with plastic ballasts melted on me after only a couple months. Luckily for that instance I was able to find a replacement set with metal ballasts. After not being able to find a suitable hid set with metal ballasts for this one I started doing research into an led conversion. I was a bit skeptical at first because of all the kits out there with poor output and concerns about the light out notification popping up due to the lower wattage. I came across the sealight led conversion which from what I’ve read seemed decent and didn’t cause any issues. I purchased this kit off amazon which was on sale at the time https://www.amazon.com/gp/product/B079KB8J98/?tag=serious-20
Installation was as easy as swapping the bulbs out. Compared to the stock halogens I wouldn’t say it’s a huge difference in terms of useable output, but it is a little brighter and the white light helps to make the road more visible and not strain my eyes which is enough to make me happy. Beam pattern seems to be the same as the halogens. It did not make the bulb notification come up either. If I were to do it again I’d look for something brighter, but seems there are limitations to the light output due to the design of these housings & the fact its already a 9005 bulb which is generally for high beams. For now I am content and still believe for the price it was still worth it.
0742-CA89-E8-E5-425-B-9987-982-A066-B0-F46 hosted at ImgBB
Image 0742-CA89-E8-E5-425-B-9987-982-A066-B0-F46 hosted in ImgBB
ibb.co
C868193-F-C29-E-499-D-9-F37-0-A7-F3-B4-B1949 hosted at ImgBB
Image C868193-F-C29-E-499-D-9-F37-0-A7-F3-B4-B1949 hosted in ImgBB
ibb.co
56-A2-A145-C88-A-482-F-ADA6-0-CB43-D8-E40-B7 hosted at ImgBB
Image 56-A2-A145-C88-A-482-F-ADA6-0-CB43-D8-E40-B7 hosted in ImgBB
ibb.co
