2stroke
- August 7, 2013
- Location
- 55302
- Annandale, MN
- 1993 Ford Explorer Sport
This is my first post, but this site has been very helpful so far. I have a mostly stock 1994 ford explorer 4x4 that I am basically stuck with right now. I'm just saying right now I dont think ford or chevy is better than one another, however I do want a chevy 1500 pickup, for the simple reason I like how they look and how they are set up. I have been towing with my explorer for a few years now, my dad is the original owner, and the thing is a tank. I think the towing limit for the auto tranny is somewhere around 5000 pounds, but I have gone way over that a few times, and it did fine. I'm on the original tranny at 215,000 miles, and I do not baby it. Infact most of it is original, motor, rims, even the alternator. The thing I had to learn with this truck, is that you have to live with it until its actually broke. Some vehicles even a squeak can quickly turn into being stuck on the road. An explorer will work, and even when something breaks, it will get you home. It never works perfect, but it ALWAYS works. The only problem with it has been it is on its 4th set of wheel bearings (however I drive in water a lot because of shallow boat launches), but I could never understand why the fronts go bad. I've never had one fly apart, but they growl until you cant hear anything. I must buy china crap bearings. The only mods I have done are 1 the rear window wiper is gone. It serves no purpose, and holds the window shut when your trying to open it. I simply poped it off the gear thing, and painted it black. The next is I cut metal pieces to fit the backs of the back seats and used 3/4" screws to attach them. After taking out the carpet, I bedlined the whole thing. I now have a regular cab, short box explorer. The last thing I did was tear the running boards off because they rusted too bad to hold anyone. I then used 12" wide aluminum roll sheeting (the thin stuff in the home improvement area) and used snips to cut it under the door and used 1/2" self tappers to attach it. I then bed lined it for looks.
I just moved to college, and cannot afford a new truck. However I was wondering if there was a reasonable way to lift it for cheap. Its at stock height right now, and I have 235/75/15 tires that are good, and I could probably get $400 for, so bigger tires wont be much more if I buy used. I am in no hurry, I drive my car around mostly, but when the football season ends I will need it to go fishing. The #1 concern is cost, less than $100 if possible. I can weld, cut, and rig up something if I have to. Doing that will be easier than getting the old stuff apart, the thing is rusted bad, even by MN standards.
I'm not certain a lift is a good Idea though. The main use of it is towing, I don't tow much more than the occasional 5000 pounds anymore (mostly a 1500 pound boat). The lift is mostly for looks by the way, I don't off road, and the only time I got stuck was on a frozen lake in 2' of snow when a lift wouldn't have helped. Actually all I needed was tire chains. The only advantage I can think of is I can use drop hitches. The hitch I got off craigslist hangs down 3" from the bumper, meaning even a 2" drop hitch puts most trailer tongue's too low. I have been using a 3" drop hitch upsides down.
I have never lifted anything before, but I am very mechanically inclined. I have done some research and I'm thinking either really small, like a 2" lift and 31" tires (yes I know they fit stock, I used to have them on), or really big like 6" with a SOA. I really like the Idea of the SOA and It is cheap, but nobody ever says how they lifted the front. I have seen it gives 5"-6". I tow alot, but mine is not sagging bad, so it will probably be closer to 6". It is sagging a little, and I like the back higher than the front, so a 5" lift i front should be perfect. what would it take to lift the front 5", and how hard is it to do on rusted parts? That should be enough questions for now.
edit: I am not looking into body lifts, as they would do more harm than good. For the 2" lift I was thinking longer shackles, and 2" spacers over the front coils.
Here's my car they day I towed it home
