- January 26, 2004
- Mechanicsville, Virginia
- 2004 Acura TL
For a no start or cranking issue - and you want to rule out the fuel pump circuitry, you can simply listen to hear the fuel pump cut on with the key turned to the ON position. This will "prime" the fuel system, meaning fuel will be pressurized into the rails. Now, to make it even easier to hear, have a friend sit in the driver seat, put a funnel (long transmission funnels are best) into the fuel tank filler neck, and get your friend to turn the key on. You should be able to hear the slightest noise inside the tank.
-Drew
NOTE: just because you hear a fuel pump cut on, doesn't mean the pump is good. It basically just means the Fuel Pump/Sending Unit circuit is ok.
-Drew
