PashRoot
- April 23, 2013
- '97 Explorer 2WD
If you've seen my previous thread you'll notice that I'm having braking issues which at this point I've confirmed are due to ABS randomly triggering when stopping which likes to slightly pull to the right.
In my ongoing quest to figure out what the deal is, I again removed the left front wheel and checked for play. There's about a half inch or so of play when moving the wheel up & down, left right, etc.
I took the wheel off, tried to move the rotor a bit, still wobbling a bit. Removed the wheel bearing cap and tugged on it again. The center nut doesn't move at all but everything around it does? I also checked for movement in the back and couldn't find anything.
Does this indicate a loose wheel bearing? Could it be what's randomly triggering ABS?
Another issue I've experienced as of late (or at least since changing my front tires) is a random low frequency groaning/grinding sound coming from the front when driving around 35 mph.
