1998 Ford Ranger 2WD 4cyl
I checked the bulbs (doesn't seem to be the problem), I checked the fuses (doesn't seem to be a problem). Both headlamps stopped working at the same time. High beams still work. When I use the MFS (that is the controller for blinkers, windshield wipers and high beams right), in certain positions, the lights go off completely, and then when I bump it again, the high beams go back on.
If I replace the MFS, should my low beams work again? Or is it something else? Thanks guys.
