bullseye1951
- November 12, 2012
- Chicagoland
- 98 Explorer XLT
98 Explorer XLT 4X4 - No high beams
I've read thru many threads here and other places about this.
Pulled and checked every fuse - all good inside and out.
Not sure if there are any relays to check - or how to check them.
Replaced both headlamp bulbs.
Replaced MFS switch with a new BorgWarner from O'Reilly
The wires and harness all looked good - no burn spots or cut wires.
Low beams and fogs, wiper/washer, hazards, turn signals work fine.
Push the stem for high beams and nada - lows go off.
Pull for high beam flash and nada.
I'm at a loss as to what else to check. I do not have a volt/ohm meter but do have a 12v test light. I'm presuming there is a problem now somewhere between the MFS and headlamp but unsure where or how to check.
Help please.
Thanks
Help please.
Thanks
