hydroxy
I like to fiddle...
- April 23, 2002
- Fairfax, VA
- 1995 Limited v6
95 limited.. have the ARC system.
I want to lower it, however I've searched all over this board, and can't find any posts w/ actual answers.
What are the options with lowering an Ex that has the ARC system, besides putting in new shocks or just turning the system to 'off'? is it even possible? has anyone done it?
There was a post about the sensor's of the ARC system putting out different voltages for different hieghts. 4.75volts or so if it is at minimum ride hieght, .25 if it is at maximum ride hieght. I was thinking that if the system was below minimum ride hieght, that the sensor would put out > 4.75 volts. Do you think that there would be a way to put a resistor on the sensor wire? ie if lowering it caused the sensor to put out 6 volts, stick a 1.25 volt resistor on. Making the computer think that the lowered hieght was the normal minimum hieght?
The next problem is locating the sensors... I've taken a quick glance at the shocks and didn't see any obvious sensors. Are they built into the shocks?
Thanks,
Patrick
Here is thread about the voltages:
http://www.explorerforum.com/forums/showthread.php?s=&threadid=89195
Thanks,
Patrick
