Mach Audio System (BLANK LCD Now FIX for $0) | Ford Explorer Forums - Serious Explorations
H@ckerBoy
Canada
1999 Eddie Bauer
BLANK Display Now FIX for $0
Hi! All.
I start laugh After reading all post ant comments,I fix myself the blank Display problem.
Here's the solution:
BE VERRY CAREFUL WITH THE POWER SUPPLY BOARD!!!!!
-(use a 30 watts FINE PEN soldering iron and thin-wire solder)-
The Blank LCD problem comes after a overheat resistors.(you don't need to replace them)
R1060 - 3.3 ohm 2W
R1061 - 1.8 ohm 2W
R1062 - 2.2 ohm 2W
R1063 - 2.2 ohm 2W
De-solder these 4 resistors and re-soldered with a 1/2inches extentions pins.(see pictures below)
-(Remember the direction and location of the resistor)
Those resistors is mounted flush to the circuit board instead to be lifted in the air.
PIONEER didn't fix this problem.
That's why these damn Display comes off.
They needs air for cooling themselves.
--(you need 4 old resistors with long legs.Cut these legs for extentions pins)
--Cost=$0
--Time=20 min
Try these steps and leave a comment!!
PICTURES:
http://www.imagup.info/images/03/1186517812_DSC00912.JPG
http://www.imagup.info/images/03/1186519224_DSC00910.JPG
http://www.imagup.info/images/03/1186519269_DSC00905.JPG
FORD EXPLORER OWNERS MANUAL 1999.pdf
I wish i could understand this :(. My display has been off for a couple years already.
