chainsawjay
- May 8, 2011
- manton michigan
- '98 limited 5.0
ok long story short. i broke a hose out of the tranny cooler and pumped about 5 quarts of fluid . I fixed the line and bought some new fluid. i live in a tiny town with one parts store and all they had was KENDALL VERSATRANS fluid which i was very hesitant on buying but the bottle said approved for service fill in fords needing merk V . put it in and everything was good for about 60 miles now my reverse is slipping sometimes. usually when the fluid is cold once its warm it has very strong reverse. also one slight slip going into fourth, maybe third not sure, but only once after i first start it. fluid level is good. its confusing i do have a clogged cat converter im sure that dont help. to check codes for the tranny do you plug into the obd port under the dash? ive had her for about a year and havent done a trans service, thats probly where ill start. cheapest first. any info is greatly appreciated. thanks.
LONG LIVE THE EXPLORER!
