wjtowne
- September 8, 2009
- Fond du Lac, WI
- 1997 Ford Explr Limited
Ok, I need some A/C help.
It started last summer. My A/C wasn't working, so I took it to the Ford dealer. They checked for leaks and said there weren't any and then recharged the system. All was good for about 3 months. Then it stopped working again. It was near winter, so I left it until this summer.
I went to the store and purchases a DIY recharge kit with gage. So, I recharged the system. Here is what I did.
Hooked up the gage to the low side valve. I was getting about 8 psi so there was still a little freon in the system. I turned on the engine and set the A/C to max. I begain recharging. Pretty soon the compressor would cycle on and off. When the low side got to about 50 psi the compressor would turn on until it dropped to about 20 (I think) then cycle off. I continued to charge until the low side stayed at about 30 psi with the compressor engaged. I was getting Ice cold air.
Question 1. When I turn off the A/C the low side pressure would rise to over 80 psi. Is this normal?
Question 2. when I remove the gage. The freon is leaking out through the schrader valve. Did I overcharge and blow the schrader valve seal?
Question 3. If the large rise in pressure on the low side with the compressor off is normal, I probably had a leak at the schader valve the whole time and the dealer didn't find it. Maybe it won't leak with a vacuum, but will with pressure. Can I replace just the schrader valve or do I need a whole piece that has the valve (not sure what part that is)?
Thanks,
Willie
Thanks,
Willie
