JohnelP
- January 5, 2018
- bbbbbbbbbbb
- Explorer 2013
XLT 4wd
@jons901 - your measurements are practically an identical replica of what i read with my FORScan on my Ford. I had used the same PIDs to monitor. My measurements are the approx the same at idle or 2k or 2.5k rpm. ~0.1 V for the 1st sensors and ~0.9V for the downstream ones.
My neighbour has an identical explorer (same engine, just one year younger), and he allowed me to measure his car, as the "good reference".
The readings on his car are identical with what we read. Steady 0.1V 1st sensors and .9V downstream ones. Both at idle and 2k rpm.
According to internet experts, that should not have happened. the 1st sensors values should oscillate between .1V to .9V.
So, either we are reading the wrong PIDs, or the PIDs we are reading have different output format? read other sensors???
In my case, I have also a bit irregular idle intermittently, that makes me investigate vacuum circuit deeper as culprit.
I broke loose the brake booster hose to see how much vacuum leak can the engine take before it stalls. It stalls pretty quickly, however, it tolerates a fair amount of leak.
As for the smoke, I am not comfortable to put inflammable spray on a hot running engine. I am trying to build the mineral oil smoke (opt1) and burn some cigarettes in a jar (opt2). For now, none of them give me the smoke i need. Still trying
