imq707s
- July 5, 2000
- Springfield, Missouri
- 1997 Mercury Mountaineer
I've got a 1997 full time AWD Mountaineer (just like an X) with 120,000 miles on it. Over the last month I've noticed a loud howling noise coming from the front drivers side tire/wheel. It only happens when I'm turning or braking at speeds under 30mph. I did a search on the message board, and it looks like this is a symptom of a bad wheel bearing(s).
I've heard that you can replace them yourself, and I've also heard that the bearings are sealed and you have to buy the entire hub assembly.....which is it??
If I CAN replace the bearing myself, can someone give me some tips and advice. If I have to buy the entire hub assembly, where is the cheapest place to get one? Can I just replace one hub assembly, or is it a good idea to replace both?
Thanks for the help
Thanks for the help
