SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
I'm in the process of doing a front brake job on my 2002 Explorer. While I'm doing the brakes I decided to repaint the calipers. I'm installing new rotors and ceramic brake pads. Anyhooo...I've got a few questions and hope anyone with the 2002 spec and other knowledge can help me out.
Torque specs for a 2002 Explorer's front brakes:
1. Torque for the caliper anchor plate bolts
2. Torque for the caliper slide pin bolts
3. Torque for the caliper brake fluid supply bolt (flow bolt?)
4. Torque for the caliper bleed screw nipple
In addition, after I removed the slide pins I noticed that the upper and lower slide pins are slightly different. One of the slide pins has a rubber bushing at the end of the pin.
5. Does the slide pin with the rubber bushing go in the top or the bottom?
6. What kind of grease do you recommend for the slide pins and is this the same stuff they call brake grease sold in tiny packs?
7. Do the copper washers need to be replaced (or reuse) on the brake fluid supply bolt?
Thanks in advance...I always appreciate your assistance!
