CdnCory
- April 17, 2004
- B.C, Canada
- '93 2-door
Here are some pics of my box. Each has 3.95 cu.ft. of airspace, and dont bother asking me what they are tuned to. I had went into a local car audio store and wanted to know what port sizes I should make, so he called the guy in NY who designed the subs and he said the port should be 23 x 8 x 1"deep, but this was before I had the box built and the guy only took rough measurements. So I made the ports as big as would fit for now, and I will be making new tops for the boxes as soon as I hear back what the ports should be for my actual box. As of now, I resined whe inside of the bottom and will just screw on the top. I still have to add 1" polyfill all the way around too.
Here I am still trying to find out how things are going to fit. I didnt measure anything, and lucked out that my three amps actually fit on the rack!
I dont really want to have my distribution block showing cuz its not the nicest looking piece of equipment in the world, so I might flush-mount my EQ underneath the component amp, then have a cutout underneath the amp so that when I have to change fuses all I have to do is remove the one amp.
Next step is to install the two yellow tops, isolator, drill all the holes for wires in the amp rack.
Once I get the finished box with the correct port, I'll probably get it painted to match the exterior and then carpet the amp rack (since I have a feeling it will be taken on and off a few times).
