koda2000
- September 2, 2011
- x
My POS '01 ST, which I've owned for about 3 years now, could use timing chain work, but spinning the engine to pump up the tensioners has kept it going so far and stopped it from making noise at start-up.
This is not our first SOHC and we had one that had HORRIBLE TC noise, which eventually jumped time and we scraped it.
A while ago my ST started making a rattling noise, which sounds a bit like timing chain noise, but when I dropped the lower oil pan I only found a small piece of spring steel, which people thought was from the jack-shaft tensioner.
About a week ago the ST's engine started making a loud clicking noise when re-started, but almost never on the first start of the day. It may or may not make the noise on hot/warm restarts, but when it does it will stop making the clicking noise after it runs for a few minutes. It kind of sounds like a collapsed lifter on an OHV engine. The clicking never returns while running once it stops.
I'm thinking it's getting closer to engine replacement time, but other than the clicking noise (and light timing chain noise at around 2700 RPM) the engine runs great and is very strong.
During my next upcoming oil change I plan to remove the lower pan again to see if I find anything new.
Any thoughts on what's causing my clicking noise? I have an opinion, but I want to know if anyone has experienced this.
For the record, I will not consider rebuilding my current engine, but I may consider swapping in a newer engine with new TC parts. Those of you that have investigated quality reman 4.0L SOHC engines know they are very expensive (around $4k) and I'm not going down that road. I'm hoping to find a good used engine for maybe $1000-$1500 and I'll install new Motorcraft TC components.
