IIISLACKERIII
- February 21, 2010
- Marengo, IL
- 1998 sport
i found a 1998 ex sport on CL it said $950. i called him found it had a problem but is fixable. i went there today and drove it home for $600. it has the sohc, and only 157000 on it, it has a fair amount of rust (but for 600 i dont care). the problem it is haveing is a ICV problem. IDK if thats the only problem. right now to start it you have to floor it and crack away at it it it starts it starts on likr 1 cly then spits and sputers away for a bit then gos to 3000 rpm then drops to 2000 and idels for like 10 sec and then is suts off. also you have to floor it to get it to get it in drive. I took the ICV off an cleaned it with gas put it back together and started it, it idled for 5 mins, slide into drive no problem i thought i fix it but then it stalled out and the same thing happend...so is it just a bad ICV????
