The clutch itself is filled with a special silicone material which gets
thicker as it gets hotter. Therefore, being like a little "torque converter", the silicone allows "slip" between the spinning engine and the fan blade, when the air coming through the radiator is relatively cool. As it gets hotter, the silicone thickens up gradually, allowing more "coupling" to take place between the spinning clutch, and the fan blade fastened to it. This is a simplified description, remember; the high-quality clutches have additional features (thermostatically-controlled internal vanes), which we are skipping over here.
Usually, the silicone fluid gradually leaks out of the clutch; this can often be seen on it, as it collects dirt. So, the clutch fails gradually, not all at once, (usually), so overheating of the engine may not be evident, as the forward motion of the vehicle pushes enough air through the radiator to keep the engine from overheating. If it's "on the brink", however, it is likely the A/C will be affected (blowing not so cold).
Test: 1. Look for evidence of the fluid leakage on the clutch. If it's there, replace the damn thing!
2. If no leakage, start engine cold, allow it to idle, and as it reaches operating temperature, the clutch will, if operating properly, begin driving the fan gradually. You can feel this by carefully checking the temperature of the air coming through by placing your hand behind, but not close to, the back of the fan area, high enough to avoid belts! When the engine is quite hot, the clutch should be driving the fan enough, even when idling, that the air it's pushing will feel
uncomfortably hot to your hand. If this is not happening, the clutch is not operating properly. In addition, if your hearing is good, you will detect the sound of the fan spinning faster as the engine gets hot. A slipping clutch with hot radiator will throw little hot air.
Try this, and let us know how it works out. Plenty of us may still regard these clutches as "magical"!
imp
