stevenphenna
- September 14, 2023
- Edgewater, CO
- 1998 Ford Explorer
I have a 98 Explorer that now won't crank or start. The battery is new, so I know that's not the issue. I've cleaned corrosion of the battery cables, but am thinking I may need to replace those. No issues with fuses.
When I take the battery cables off and then put them back on, I'm able to get the headlights/dash lights on sometimes, but other times they go off. Even when headlights are on, if I go to start it, it doesn't crank or turn on, and it kills the headlights/dash lights. When this first happened, I was able to start the car with a jump battery.
Any ideas? I'm a bit of a noob so any advice is appreciated. My plan is to try new cables, then if that doesn't work, perhaps take the starter off and get that tested.
