alohamonte
- October 4, 2007
- Glendale, AZ
- 1998 Explorer 4.0 4x4
Hi Forumites,
1998 ford explorer... I have a problem with my lights. The headlights do not work. The turn signals, hazards, and parking lights work. The high beams will work if I pull back on the toggle/lever, but they will not work if I click them forward into place. The headlights do not work at all.
So far I have
- replaced both headlight bulbs
- replaced the multi-function switch on the column
No change/improvement with those two replacements. My thought was inspect the fuses next. Are the headlight fuses under the hood? side of the dash? Not sure of their location.
Is there a headlight relay that I should be looking for? Just looking for a point in the right direction. Thanks
So far I have
