johnwartjr
- December 28, 2009
- Columbus, Indiana
- '96 Limited
96 Limited V6
18x,x.. miles
This is our 'spare' vehicle, so it's sat for the last 6 months, other than to start it up a couple times and drive it around the block.
I decided to change the oil.
After changing the oil, the 'check gauge' light is on, and the oil pressure gauge shows no oil pressure.
It was at its typical mid way position before changing the oil.
I've verified the oil is at the correct level, the drain plug and filter are both tight and not leaking.
I know the oil pressure sensor is nowhere near where I was working while changing the oil.
How should I troubleshoot this problem? It starts and runs, doesn't make any funny sounds or metal on metal type noises..
18x,x.. miles
