Bill in Denver
- March 5, 2023
- Parker, CO
- 2001 Sport Trac
I didn't find the specific answer so I thought I throw it out. 2001 Sport Trac, relays tested, voltage to pin 30 of FP relay and PCM relay, fuses ohm good, but there is no voltage on the grn/wht wire at the inertia switch. I did hot wire 12v to the pink/blk to energize the pump directly and the 15a fused wire I used to hotwire it immediately popped the fuse. So while the pump may be bad (or a short between the inertia switch and pump) that doesn't explain no power at the lead side of the inertia switch when everything back upstream checks ok.
Ideas?
thanks
Bill
Ideas?
thanks
Bill
