- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
we are 14 degrees right now, but it is to be 54 on Thursday the 29th
Wait one minute.what the heck is going on with this thing
the problem here is with the pats e the old SOHC PCM was the pats module....so with that PCM gone the PATS E system is not complete and will never work.
As long as your 5.0 PCM, the receiver behind the dash and the key all match and the PATS B system is wired in properly the starter should turn and the truck should start!! You should have a blinking THEFT light that goes out when cranking the starter.
Did the PATS b system work in the 5.0 donor?
I have successfully added pats B system to trucks from 96 up to 2002 I am not sure why you are having issues!
the pats B disables the injectors, not the starter...
Pats e disables the starter
I wish I was there with our heads together we could sort this out in short order, I hate internet "mechanic ing" when things go south
dude
Yes the 5.0 PCM is looking for IT'S key and its PATS receiver
Yes you need to be using the 5.0 key AND pats module that came with the 5.0 donor.
The pats B system must all be complete:
5.0 computer, 5.0 key (and ignition tumbler) and the 5.0 pats receiver from behind the airbag
Those are all of the components of the PATS B system
The pats E system consists of the 2002 key and the 2002 PCM, the v6 went bye bye so did the pats e brain (v6 PCM)
With pats E the PCM IS the receiver........no more v6, no more v6 computer = PATS E was REMOVED from the vehicle.
I know why it wont run, it never will until you either:
install the entire pats B system into the donor truck
or
Flash the 5.0 PCM to remove PATS
I think you are onto something here!!
