- February 25, 2011
- Moderator
- 2020 Explorer ST
Looks convenient, but for me there's too much risk involved with the lack of security&simplicity compared to a standard drain plug. You can get really good at hitting the drain bucket. For starters place it so that one edge of the drain pan is just under the drain plug with the far edge away in the direction the oil shoots out. The first time you do this be ready to make a quick adjustment on the drain bucket's position. Wear nitrile gloves. Have plenty of paper towels or old rags available. On the filter-Back it off just enough to let the oil dribble out past the seal and return to completely remove it about 10 minutes later.
On flat ground you can't even wheel yourself under your Ex. Do you really think someone is going to crawl underneath and empty your oil in a parking lot? These have been used for years on so many vehicles from so many forums that I am on. It is a very well known and quality item and makes oil changes a breeze.
