Brian's98XLT
- December 18, 1999
- Wisconsin
- 98 XLT
If you are running your amp and it is always clipping the output you will end up burning out the voice coil and /or the outputs in the amp. If you are talking about the cheap import amps you are right most are overrated by alot. They rate them by the Lighting factor. Yeh that $200 1000 watt amp with the 20 amp fuse will put out 1000 watts when lighting strick it.
But I work for a dealer that is authorized for Alpine, MTX, XTANT,Rockford, Kenwood, Kenwood Excelon, Sony, Sony Mobile ES, MB Quart, Infinity, CLarion,Clarion PRO Audio, Kicker and a few more. All of these manufactures all under rate the output of there amps. I guess it is just what you are used to working with that makes a differance.
