biggermike
- January 7, 2015
- 2008 Sport Trac
Hi there. The other day i was driving to work and my entire instrument panel blacked out for roughly two seconds, and rebooted - burying the tach/speedo etc before finding the correct speed and revs. Not sure if this has anything to do with it, but it was minus 28C at the time.
The next day, (not too cold...maybe minus 14C) - everything worked fine.
Today (minus 35C), my abs and slip would kick on and off, instrument panel would go off and on, and i could hear little clicks (relays?) in the dash area.
I tested my battery, 12.5, and 14.57 while running. Aside from bending over and prelubing myself prior going to the mechanic for them to run their tests... does anyone have any other suggestions or ideas as to what it could be? The thing starts fine...runs fine...(loses a bit of power when the dash lights go out, but has never failed). Im out of ideas... I cannot replicate the issue... just happens when it wants to. It seems to be getting worse/more frequent, but i cant drive and hold a multimeter to the battery terminals to see if it is infact a voltage drop, or if its isolated to the inside of the car. Hopefully someone can help me out.
