rmkilc
- November 5, 2018
- Vancouver, WA
- 2015 Ford Explorer Sport
Correct, no noise after 16 months and about 16,000 miles. When the OEM bushing separates so the rubber and metal washer are no longer one unit, the washer slides back and forth and gets caught up at an angle on the teeth of the rack. This is what causes the noise each time it gets hung up on a tooth and is forced until it slips off.You are around 16 months of using this and notice no noise? I would be curious to see your results after this amount of time has passed and the wear level on your fix.
I've been doing my best to try to isolate this popping noise I started having after a new K-member/control arm/inner tie rod were replaced as a result of a wreck. Later had my axle on my driver side replaced as well and this noise is still present. Only thing I can narrow it down to is the washer/bushing that you have figured out.
Even if my method eventually fails, since it's all plastic, there should be no noticeable hang up.
