Jordan4461
- June 29, 2018
- Location
- ZOO Parkway
- Asheboro, NC
- 2008 Explorer Eddie Bauer
Howdy folks,
I just finished up replacing the water pump, EGR Valve Throttle Position Sensor, Coil, Spark Plug Wires and Plugs, Air Filter, PCV Valve, Radiator Hoses, Thermostat Housing O-Ring, Bypass Coolant Hose, Heater Valve and Heater Hoses. After all of that, started the 2008 4.0 liter with 194,000 miles, and it was leak-free and purring. Wonderful!
But.
Then I decided to change the Fuel Filter. After removing the two metal shields, I found that the filter had been changed sometime in the past. The "quick-connect" on the inlet side looked like it had been chewed on and the little red tab was open. I can't get close enough to tell for sure, but I suspect the tab is supposed to be opened and the whole tab pushed out the back of the connector? The outlet side had a white plastic tab that pushed through and allowed the filter to release on the outlet end, but when it pushed through the connector, it made a little "ping" sound and launched itself into a black hole. Still can't find it after looking for 2 hours. I think I found a replacement plastic retainer at Autozone, so I'll try it tomorrow. If anyone know where I can locate one of the Red retainers like the one that is on the Inlet side of the Fuel Filter, please let me know. I really don't want to have to replace the whole Fuel line from the gas tank to the Fuel Filter. If I can't find the retainer, I may resort to cutting the line and inserting a barbed connector and use a hose clamp to keep it attached to the Fuel Hose, then connect to the new Filter. Anyone done this?
Thanks for all inspiration and knowledge!
But.
