Icepick2010
- February 11, 2010
- So Cal
- 2002 XLS
What's the recommended jacking procedure for jacking up the rear end of a 3rd Gen. Ford Explorer.
I plan on changing the front and rear brake pads and will start in the back. I have a floor jack and two jack stands. Is there a good rear center place to jack up to get both stands under each side at once? It doesn't seem like the rear diff. is a good place to jack from.
Is it safe to jack one side via the frame rail - place a jack stand - and then jack the other side with the opposite side resting on the placed jack stand?
Or I guess the third option is to just jack and work on and finish one side then lower and jack up the other side.
What methods do others here use?
Thanks
Thanks
